What chain to use
stupug
What's the best chain for a road bike ss? As I've read different things about the uses of two different chain sizes.
Sharky
Kent
Sprockets are either 1/8th or 3/32 in width. If you are using 1/8th, then you must use a 1/8th chain. If 3/32 sprocket, then both will chain widths will work.
stupug
stupug
Thanks, still waiting for my new wheels to arrive so will measure the sprocket when I get it. Is it just the distance between the teeth?
Sharky
Kent
No it's the width of the sprockets. The distance between the teeth (aka pitch) is always 1/2inch like all chains.
Cheers keith
stupug
stupug
The wheels I ordered comes with a sprocket with it. But I can't find out anything from the company until Monday as they're shut
stupug
stupug
Is it the chainring not the sprocket I need to measure? Or do I need to match them both?
Tim Hall
Crawley
The chain needs to work with both the chain ring and the sprocket, as it runs over both of them. Which wheels did you order? What is the chain ring/crankset fitted to the bike? But as mentioned upthread, 1/8th chain will work with both 3/32 and 1/8th sprocket & chain ring.
Sharky
Kent
Are you sure the wheels are coming with a sprocket. This would be a bit unusual, unless you have specifically ordered one. But the wheels should come with a lock ring on the fixed side?
Anyway you'll soon find out and any bike shop will have a suitable chain.
Cheers
3narf
For whom the bell dings
Tetbury
My flipflop wheels came with a fixed sprocket. It's 3/32".
If you have a 3/32" sprocket/chainring with a 1/8" chain, the chain may theoretically move about more and wear things out quicker... Doubt it will make much difference though.
I use a 1/8" chainring and chain with a 3/32" sprocket.
