Shearwater Missile
- Stowmarket
Fixed the same puncture twice.
Had a piece of flint put a large cut through the tyre making the hole in the tube easy to find and fix. The first self adhesive patch used (last one from an otherwise empty strip) must have been in the kit for a long while as it lasted for all of a few hundred yards before the glue stopped sticking and the tube went down and needed re-patching using the first from another strip.
The most annoying thing is that the tyre looks like it will need to be replaced - it's only done 75 miles from new as a replacement for one that had almost exactly the same sort of cut. The bulge at the bottom of the cut is where the tube is poking through the carcase so I've deflated it and will have a proper look later tomorrow, but I don't think a tyre boot will help.
That looks a pretty bad cut. Around here, they are putting a lot of stone chips down, redressing if you like. It makes me uneasy, as 1, all the loose stuff makes it dangerous and 2, some of the sharp bits are liable to go into a tyre. Years ago, on one of my commutes to Felixstowe Rd in Ipswich, Derby Rd had just been dressed. Lunchtime, I always made it a habit of checking my tyres. Sure enough, one tyre was down. It was a small piece from the redressing. Glad I checked it then and not found out when I was about to leave off.
I think you are right, that looks like a new tyre job !
