What inner tubes do I need?
sionhughes
arch684
It should tell you on your tyres
What width are the tyres? As arch says, look for something like 700x ?? On the sidewall
The bike presumably has the skinnier presta valves? I'd get long valve ones. Halfords do 5 tubes for a tenner
Don't forget to carry a good pump too and make sure you know if works before venturing out. Most can be frame mounted
sionhughes
sionhughes
sidevalve
Either - whichever is in you local Halfords. The variation is because tubes will expand to fit slightly larger tyre sizes.
PS - don't forget to check online as there are some good deals available on tubes.
On an entry level bike, the tyres are usually quite poor. You might want to save up for tyres with better puncture protection if you are going to be using the bike regularly, for commuting, on crappy roads etc
Schwalbe marathon plus, don't roll too fast but rarely puncture
http://www.wiggle.co.uk/schwalbe-ma...ccoSYFmQ_dt|pcrid||pkw||pmt||prd|5360646512uk
You might look at putting a 35mm on (so buy the narrower tubes) if road riding
Regarding innner tubes, they are much of a muchness. I'm quite happy with the halfords ones, and I've used specialized and Schwalbe too (and wilkinsons which admittedly are rubbish). Spend the extra money in the tyres, so you don't need to change them tubes so often
Dirk
If 6 Was 9
I've had more punctures than you'd care for on cheap 'Halfords' brand tubes - three in two miles once on my folding bike! Eventually learned my lesson and only buy decent quality tubes now. The old adage is true - you only get what you pay for.
sionhughes
sionhughes
Thanks for the advice everyone. Will get myself some inner tubes now I know the right size and will add new tyres to my wish list going forward! After some clipless shoes first though! Thank you again!
arch684
If your going clipless make sure you practice unclipping before you go out on the road
I'd say it's more down to the tyres. I've had few punctures, but on a range of tubes
Saluki
I've run away with my friends to..
...New Tealandia
Good deals to be had on shoes at Go Outdoors at the mo but I'd be changing the tyres and tubes first. Tyres are not wildly expensive in the grand scheme of things. Have you had a look at Wiggle? you get a bag of haribo with every order.
