LetMeEatCake
- Under a cloud, Glasgow
Choices, choices!
- If you've got at least a 300W power supply and don't mind spending a bit more, then tincan's GTX 750 is a good choice, and you won't have problems with power connectors. If it works, this will give the best on-screen results.
- fossy's GTX 460 card isn't quite as powerful but needs more actual power (Watts) which may be in issue for your power supply. Min 450W power supply required. It is, however, cheaper. Note that it needs two free internal PCI power cables which your PC may not have.
- crackle's HD 5450 will almost certainly work, is cheap, but is much less powerful than the other two.
