what pumps
oliver
oxfordshire
i currently have a pump for my road bike but it strugles to get anything past 50-60psi before making an anoing hissing sound and not pumping
i was wondering if anyone had any recomendations for a pump that can do 110psi - preferably cheaper the better
scouserinlondon
I have a bontranger track pump, under £20 from Evans, does the job.
Martok
Klingon on a bike
Watford
If you're after a floor pump (and I'd highly recommend you get one if you haven't already) then I use a Topeak Joe Blow Sport, which does up to 160psi. £27.99 from Evans
If it's a pump to carry with you for topping up when needed etc, then I use a Topeak Mini Master Blaster Mini DXG Pump which has a guage and a SmartHead™ which fits Presta or Schrader valves automatically without having to fiddle around. £17.59 from Wiggle
georgiebuzz
+1 for Topeak, but I have the Morph Turbo. It gets to 120 psi without too much trouble. These days I do keep it on my mountain bike, and use a Second Wind C02 pump on my road bike but the Topeak is used to keep my tyres at the right pressure (easy to use and has a pressure gauge) but prefer to go a bit more lightweight on my road bike.
Hand pump - Blackburn Air stick Carbon (for a bit of flash), or Decathlon's Clever 900 (the Decathlon one is heavy - makes a good commuter pump though).
Track pump - get a good one - I have a Silca pump from 20 years ago that still works great.
Norm
Browser said:
I've just got a Topeak Road Morph G , superb bit of kit, does my tyres up to 110 psi no bother.
I bought one of these earlier after my old pump gave up on me yesterday and I was helped out by my riding buddy who had the Road Morph G. Excellent piece of kit.
PpPete
Chandler's Ford
Excellent pump IMO. 120psi no problem.
Rather less impressed with the Topeak Mini with Gauge. The "push" stroke is fine, but I really dislike the "dual action" as it's really hard to pull once the pressure gets up to about 80psi. Wish I'd got a Road Morph to take out on rides.
stevepratt48
Try a smear of vaseline (Oooooh, Matron!) around the pump piston seal, before you give up, makes a huge difference!
I use Topeak master blaster (Ally body, A1)
Sun Superlight
I use a Specialized Air Tool road pump and have found it to be reliable and also reasonably priced at around £12. (for presta valves only)
Achieving 90psi with it is easy, 110psi takes just a little effort.
(It seems to be available at all the Specialized Bike stockists that I've been in)
ASC1951
Yorkshire
stevepratt48 said:
Try a smear of vaseline around the pump piston seal, before you give up, makes a huge difference!
Top tip, there.
I usually go months between punctures out on the road. Having been caught out once, I now dismantle my Blackburn every few weeks and re-grease the piston floating seal. I use silicon grease rather than Vaseline, on the perhaps spurious grounds that petroleum jelly gradually rots any rubber compounds; it's a hangover from diving days.
