what tool do i need
3tyretrackterry
East Midlands UK
Gerry Attrick
Er..to do what?
Gerry Attrick
Ah yes, ideally you need a c-spanner, either adjustable or a fixed one of the correct size. Now I shouldn't really tell you this as more lock rings have been damaged by using a hammer and punch to undo them than there are stars in the sky, but you could try a hammer and punch.....gently!
However, slackening the lock ring is half the problem, then you have to undo the adjustable cup. I can't see from the picture which type you have, but it will need either a pin spanner for the holes, or a thin spanner across the flats if there are any.
3tyretrackterry
East Midlands UK
on the other side is a metal ring which looks like the plastic version that are on shimano BB cassettes I also have the tool for removing this as well I am hoping that this is a cassette assembly rather than ballbearing and races
Steve Austin
The Marmalade Kid
Mlehworld
That looks like a octalink cartridge BB to me.
You need
the right size allen key
crank puller
and a spanner to undo the BB cups
Its an easy job but if you are rarely going to change the BB, the price of the tools make it expensive.
Steve Austin
The Marmalade Kid
Mlehworld
3tyretrackterry
East Midlands UK
have just checked the crankset again and there is a number stamped into it fc 5500/5503 so looking at it it must be an octalink BB
thanks for the help
i must need an adaptor to extract the crankset am i correct
