You can use the spreadsheet from
here. It automatically tabulates your geared-wheel set up in inches (which is the "equivalent" diameter of an un-geared wheel) for whatever tyre/chainring/cassette configuration you have. Obvious only the rear tyre spec is relevant.
Cadence is then Speed (in mph) x 336 / Geared-wheel (in inches). If you were on 26 x 1.5" (i.e. 38-559 tyres) your cadence was around 125.4 rpm.
If you don't have Excel, although I have not tried it, the spreadset might work on the NeoOffice freeware Mac.
