What's your favourite engine?
Bonefish Blues
Banging donk
52 Festive Road
TheDoctor
The TerrorVortex
Merlin.
I was at Great Gransden in 2014 for the two Lancasters display. One Merlin sounds great, but eight was incredible.
RR Olympus.
Saw XH558 display at Shuttleworth a few times, including the last display flight.
RR Snecma Olympus 593
I was near the end of the runway when G-AXDN landed at Duxford in 1977.
Bonefish Blues
Banging donk
52 Festive Road
That's a terrible piece of design - ergonomics are all wrong.
Anyone who chooses to ride it clearly has gonads the size of medicine balls. Where would they fit?
Drago
The Urban Fringe
I'd have to flop them over my shoulder and tuck one each in my rear trouser pockets.
I've ridden some lairy bikes in my time, but even I would take a respectful step backwards if offered a go on a 250MPH jet turbine powered widowmaker.
PapaZita
St. Albans
I always liked Citroen‘s flat twin and flat four from the 2CV and GS respectively.
But the one that always fascinated me was their Type P1, an experimental engine from the 1960s. An 1800cc two stroke V4, with a supercharger driven by a separate 200cc four stroke engine in the same block. With the boost controlled independently of the main engine it was sufficiently torquey that it only needed one forward gear and a torque converter. It can’t have been quite as brilliant as it sounds, as it obviously never went into production.
1. Napier ‘Deltic’
When l was at secondary school, it stood alongside the Leeds -Wakefield- Doncaster line, so the ‘55’ was a regular sound, before the HST took over
View: https://youtu.be/_7rod4DuCr4?si=4iNYv3lqlFmIVIgb
2. Magnum’ V8
440 cubic inch (circa 7.5 litre)
Walk directly behind a car, with one of those & appropriate tail-pipes, & you feel it, as much as hear it!
View: https://youtu.be/KuWhE-skt_s?si=sFfSTjByQz-axcRW
3. Rover V8 (a Buick design)
In most varients
The 101FC, & TVR Griffith 500, are the best sounding of the bunch to me
View: https://youtu.be/5g8NTTwipfA?si=DIxif0o5oSNxg4K2
A primary reason for suggesting the 101FC, is that no-one who just sees it as an ‘ex-Army truck’ expects that V8 burble
(unless re-engines, of course)
View: https://youtu.be/krTuoVE05OY?si=MUEipKd-zCnH-lVn
dicko
Derbyshire
Both Ford cross-flow and the Pinto engines were extremely reliable and so so easy to work on.
I converted the entire BMC petrol and diesel range of engines (Newage Marine) for marine use with cast iron sump’s and water intercoolers again so easy to work with.
