What's your favourite engine?
Profpointy
An engineer friend, fellow student at Reading, was doing research on the Humphrey pump. This has a liquid piston - the same water that it's pumping - with non-return valves either side at the base and conventional inlet and exhaust valves, and spark plug at the top of the cylinder.
He built a laboratory version with a glass cylinder, to demonstrate to his tutor and visiting professors. Partway through the visit it exploded, showering everyone with water and shards of glass. https://en.wikipedia.org/wiki/Humphrey_pump
That is a really clever idea. And once you've seen it is seemingly "obvious" yet I'd not have thought of it
Profpointy
Another vote for the Deltic engine
Another rather splendid Napier engine was the interwar W12 Lion. Originally an aero engine but found it's way into land speed record cars an fast naval boats
Yellow Fang
Yellow Fang
Bury St Edmunds
I thought about the Merlin. It was definitely the most crucial British aircraft engine during WW2. It went through a great deal of development throughout the war. I have often which aircraft was most important to us in the war, Spitfire or Hurricane, but for engines it is easy. After the Merlin, I would count the various Bristol engines as the next most important, Mercury, Pegasus, Hercules. I would count the Napier Sabre as the third most important, British aircraft engine of WW2, and the Roll Royce Griffin as the fourth.
Merlin.
I was at Great Gransden in 2014 for the two Lancasters display. One Merlin sounds great, but eight was incredible.
RR Olympus.
Saw XH558 display at Shuttleworth a few times, including the last display flight.
I've been to East Kirby a couple of times, when they're running/taxying 'Just Jane', & you can get close, when they're firing up all 4 Merlins
The damn tailplane starts shimmying, with the slip-stream & vibration!!
View: https://youtu.be/bMu6363MWLc?si=bTRc0CEEfeVKk0Ni
If you want to pay, you can have a taxi-ride; https://www.lincsaviation.co.uk/
Seen XH558 take off/land a few times
Sadly only once similar to this, almost a Cold War Scramble
View: https://youtu.be/Og-HOG48o-Y?si=eB4O3R_cHX6hklR4
FishFright
More wheels than sense
Small Block Chevy , it can do most things it's ask to do very well and did it for decades.
