classic33
Leg End Member
Check your local library, they may have the book in stock is another option.Don't know about 26" on the front,
if you have never built anything like this before then I would buy the plans like I did
none of my local libaries would have anything like atomic zombie plans! oh well they are only a tenner!Check your local library, they may have the book in stock is another option.
You won't know until you try.none of my local libaries would have anything like atomic zombie plans! oh well they are only a tenner!
Cheers Ed
what other bits you nicking off the trailer?im just doing the same thing im building a recumbent trike and iv looked for wheels for the front i found on ebay they do cycle trailers i picked one that can take upto 150kg and has 2 x 20" quick release wheels.it was about £60 and im also salverging several other parts from the trailer for my trike. the wheels have a extended axle on one side that slides into a polly bush inserted into some 25mm tubing and im welding a section of tube to the bottom of my headset so i can slide the wheels in and they just click in they seem to be working well and im looking at makeing some brakes for them to just not got that far yet lol
i did look at wheelchair wheels but they cost more than the trailer and i get more parts from the trailer.
i can see what you mean it was just a quick test! still better than what i have (nothing!)i didnt take any pics of my build of my tester trike i have a couple of finished pics hopefully i will be abel to add them here
like i said before this was a quick whack parts together it took me about 6hrs to build this i used 2 old mountain bikes the trailer that iv mentioned before and a length of 1.6mm thick 60mm diameter mild steal wood burning stove flue and a couple of skateboard wheels and its welded together with a ark welder and 2.5mm welding rods. just after these pics were taken i added a rear deraililar and that helped alot with getting going and holding the slack out of the bottom of the chain.
this was just an experiment to see if i liked a recumbent trike, and also to give myself some ideas of how i wanted the final bike to be. and it has given me some great ideas so now im just waiting on the metal so i can build what will be my perfect recumbent trike
im going to be using 2.5mm x 40mm x 40mm box section for the main frame with a few strengthening pieces of 2mm x 20mm x 20mm box section. and i will probably be using the ark welder unless i find a couple hundred pounds somewhere and get myself a mig welder
i do prefer a mig to an ark i find i can get a strong secure weld with either type but if i want a weld to look neat then i go for mig i can get a neat weld almost every time where as i tend to stop and start a lot more with an ark so i can never get a decent seam.
i will be taking pics of my build when the metal arrives and i will try and sort out pics of how iv done bits so far
stuee
