SoloCyclist
I've been riding a Compact setup for around 5yrs. This has resulted in me rarely needing to use the smaller chainring except for the really steeper climbs. I took my new bike for a spin today and this has a standard 53/39 and 12-25 at the back.
This has me thinking that I probably have never learned exactly how to use the gears to best effect. Just now I will stay in the 53 till I run out of power then shift down. But, going from 53-23, assuming I don't use the 25 while in the largest chainring, means I have to shift up the cogs or I will be in too low a gear. This kills momentum.
So if I'm approaching a climb I know well and won't be able to stay in the 53 should I down shift onto the 39 at the bottom and then I can come down the gears as and when I need to?
What if I'm in an area that I don't know so well. Say I encounter an unexpected sharp increase in gradient. I'm in 53/23 should I drop to the 39 then adjust to a cog that suits, or is there a better way? Is it advisable to double shift using both shifters at once?
