When you're tired of cycling
esoxlucius
No such thing as bad weather, just poor clothing choices
Why say this, when if you read through my post I say exactly the same thing in the last paragraph!!
I don't mind being out in the rain. That's fine. But actually setting off while it's raining sets off the voice in my head that says "only an idiot would go out in this". If it starts raining 10 minutes in - one minute even - no problem. But leaving a dry house to go into the rain, I don't like that
I am exactly the same. I have good various weather gear to wear, and I have raceblade mudguards for the bike. If I'm mid ride and the heavens open, so what, but the slightest hint of raindrops on the window before I set off and that's the ride cancelled. It seems I'm not the only one with this funny quirk!
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Don’t be so serious 🙃
N0bodyOfTheGoat
Hampshire, UK
I don't take this concept of "no such thing as bad weather, just incorrect clothing" in isolation.
As an ex-postie, you get used to going out in all weather, from approx -10C during Beast Of The East to approx +37C during one of the July '22 heatwaves.
But what stops me going out cycling in bad weather, at least on nicer bikes, is I don't want a load of gritty water thrown all over the 105 drivetrain that will increase the wear rate without a good clean after the ride.
I'm still not sure if I'll go out in bad weather on the ebike with Tiagra, for exactly the same reason.
The hybrid Marasa had to get me to work in all weather until my unexpected final shift almost three years ago to the day and I just accepted consumable drivetrain bits would need replacing more often, but they wouldn't cost a kidney being 3x9 Sora.
Like many others, I've paid a price for riding outdoors in bad weather. I lost four teeth, fractured my upper jaw into a jigsaw and mangled my right hand, days after turning 40 in the Xmas '13 storm.
Plus when there's a decent turbo like my H3 setup ready to go with a bike fitted, it makes it even harder to justify going out in bad weather.
But each to their own!
Webbo2
I have cycling clothing that will cope with below freezing temperatures but there’s no way I’m heading out if there’s any risk of ice on the roads. I’d much rather use the turbo than spend months with a limb in a pot.
Webbo2
How weird
Rather than spraying up your back the water goes all over your bike.
Sloth
Are you actually not enjoying the riding, or are you simply struggling to motivate yourself out of the door?
I used to run a lot before Achilles issues made me get a bike.
There’s an old saying ‘the hardest part of the run (ride) is getting out the door‘.
I’ve never been on a run or ride that I didn’t (eventually) enjoy.
Although I tend to hate the first 15 minutes or so until my body wakes up.
However, if you no longer enjoy it at all, even when doing it then the above is no help I suppose.
esoxlucius
I think I'd rather protect my face, arse and back during the ride than my drivetrain, which can be thoroughly cleaned after the ride.
Unless there are all singing all dancing guards which protect the bike and the rider? I'm not sure you can have it both ways.
Dogtrousers
Lefty tighty. Get it righty.
On my bike the water is spat out of the leading edge of the mudguard, that's below the BB at rear and over the front wheel. It doesn't spray out of the sides. I suppose if you have those skinny flat mudguards rather than U shaped ones it might do that.
