Where in the UK can I get some Tektro brake pads P437?
MBosh
I can't seem to find the Tektro brake pads P437 for sale anywhere. I saw them on Wiggle last month, but they don't sell them now. Does anyone know where I can get them from in the UK or which brake pads have replaced them?
lejogger
Wirral
Are they disc or rim brakes?
lejogger
Wirral
Is there a specific reason you’re after that model? Brake pads are generally universal and you could probably get a decent upgrade for a reasonable price... I.e. throw some SwissStops on there or similar
M
MBosh
Do you have a link to some others similar to these? I'm not bothered about the brand, it's just with these ones I don't even have to remove the wheel. Plus I purchased some other ones once and found them to be too long. Cheers!
lejogger
Wirral
I’ve googled Tektro P437 and I can’t see an image of them to know what to advise you. Is that definitely the right model number? Is it a road bike? A picture would be really handy.
M
MBosh
Try your Local bike shop :okay:
I wanted to get some online because they are cheaper. I also have to make an appointment with the LBS because of Covid19 and they don't answer the phone. I called and they had the door locked with nobody to be seen, so not sure how your supposed to make an appoint. The note on the door says to ring.
M
MBosh
Here's a pic.
lejogger
Wirral
If you’re replacing the entire block then how were the ones you bought too long? Were they TOO long or just long-er?
Although... I’m very much an advocate of doing as much as I possibly can myself.
i’m all for supporting local shops... I popped my winter bike in for a new PF bb a couple of weeks ago, but I do all my own brake pads 😉
I meant s/he could buy the pads there
lejogger
Wirral
of course! Might just be how my weird brain works but I tend to go for an all or nothing approach at the LBS. If I go there for parts then they also fit them. Otherwise I buy online. I’m generally after quite specific things that they don’t always carry a stock of.
