Which maps?
Starting to plan my trip next summer and wonder what maps I should buy? Someone recommended Michelin but I can't remember the scale they recommended. Looking for maps of France, Switzerland and Austria.
xilios
Maastricht, NL
Michelin maps 1:200.000 is what we use. They are prety good for long distance cycling. I would not go much higher than that as they don't show enough detail and smaller you need too many.
We just received the free brochure of Austria from this site and its quite helpfull with many tips http://www.radtouren.at/en/start.html.
Maybe you could find something like this for France and Switzerland.
cheers
HJ
Cycling in Scotland
Auld Reekie
Omni do a good range of cycle maps see here. Also I can recommend the Verlag Esterbauer bikeline guides, even though most of them are in German, the maps are very good and the map legend is given in English as well, they are worth getting just for the maps.
mark
Frisco, CO, USA
Michelin does really good regional maps of France that you can get in any French supermarket. You can also find them by searching Amazon.co.uk for "Michelin Local Maps France".
IGN (Institut Geographique Nationale) also do really good maps, but I was perfectly happy with the Michelin maps.
Tim Bennet.
Entirely Average Member
S of Kendal
Michelin no longer do the 1:200000 yellow covered maps which were the staple of cycle tourist for years. They now do them by 'Department' and the scale varies from map to map, although the detail is no different. They are simply photo enlargements of the same style of map, which can be awkward to join together as nothing matches up. However the originals are still available as a road atlas, and many people use pages torn from these as an economical way of getting a lot of coverage. However this means you do have to set off with all your maps and not buy them as you go along and they can be awkward to use. This also will only do in France. The Michelin coverage of other countries is good, but often at scales smaller than 1:200000 which is not so good for cycling.
Also all Michelin maps suffer from the same draw back. Despite the fantastic quality of the cartography and the regular updates, none of them show relief by either shading or contours. The 'wiggliness' of the road, the use of green 'scenic' over print, spot heights and a good knowledge of the country's geography can all help compensate, but this is the clear advantage of the IGN maps.
So these days I think the rather shambolic coverage of the 'new' Michelin local series and the lack of relief markings has now swung the balance in favour of IGN.
Cathryn
Cathryn
So scale-wise I'm after 1:200,000? I'll check out all the recommendations, thanks. I foresee a lovely afternoon in Stanfords in Covent Garden at the start of 2008!!!! I'm def going for bikeline in Austria, and the Veloland books for Swizterland but France seems to be a bit problematic.
Oh well..I have about a year to sort the issues.
