I'd say the Crud road racer II guards are superior to the SKS Race Blades.
I'd not looked at those before but surely you need some clearance (as in with the SKS full).
Out of personal curiosity (can't tell from the wiggle pic), how many fitting points do they have? I've got my race blades set so they don't bang against the tyre even on bumps but the cruds look like they'd always be hitting my tyre. I'm assuming they don't?
Ta
Two fitting points - the supports and a cable tie up top. they are designed for roadbikes so only require a tiny bit of clearance.
They fit 700c24 & 23 fine, anything else, well, your mileage may vary. If you set them up properly they make no noise and do not contact the tyre. They feature a somewhat strange guidance system: soft pads are fitted at the point where they go over the wheel rim keep the guard from contacting the tyre.
I like them, they work well for me, but I run 700*24mm.
So winter will be coming along soon and I am not sure what mud guards to get.
Any ideas ?
I have a Scott Sub 20 with 700cc tyres
Thanks in advance.
