Moronic question time again. Can anyone clarify for me why cx tyres need less pressure? Sure it's a simple explanation, but I can't figure it out. Is it just because the bike is supposed to be on trails? In which case if it is often on the road can the pressure be increased?
So why can't you put 100psi in cx tyres when on the road, like a normal road bike tyre? What would happen?Lower pressure gives the tyre more grip and allows for a more comfortable ride off road. I occasionally ride my CX bike on the road and will inflate to 60-70psi.
The CX tyre in front of me is max 80psi. Im not sure I want to find out what over inflating it would doSo why can't you put 100psi in cx tyres when on the road, like a normal road bike tyre? What would happen?
You don't want to inflate the tyre to more than it maximum recommended limits, this you can see on the side of the tyre. If it states 100psi as a maximum then you'll be ok running them at that pressure.So why can't you put 100psi in cx tyres when on the road, like a normal road bike tyre? What would happen?
"Tyre pressure is given in pressure per area"?!Mytste is right. It is not that you inflate cross tyres less because you'll be riding cross, you inflate them less because wider tyres can't take as much pressure as narrow tyres. The reason for this is simple. Tyre pressure is given in Pressure per Area. So, if you have a pressure of 100 on an area of 5 and that's the maximum that tyre bead can resist being pulled off the rim, then that same tyre bead won't be able to resist a pressure of 100 on an area of 10. The force is cumulative. on the first example the bead experiences 500, on the second one it experiences 1 000. Dont' worry about the units, just look at the numbers.
Tyre pressure is tyre pressure.
Think your physics is a bit confused there.
You are right, it was late and I should not have been posting under the influence."Tyre pressure is given in pressure per area"?!
