Chris S
- Birmingham
I can't see why they wouldn't work if the pointed upwards from the cassette. They'd be a lot less likely to get hit as well.
How about if the derailleur was also 'flipped' through a 180 degrees?That'd only work if you pedalled backwards or the derailleur would just collapse. Think about it![]()
So when I ring Vitus in France and ask for a "little metally bits that fail first before the derailleur" they will know what I mean?top tip...
keep a spare one of the "little metally bits that fail first before the derailleur"
its' "great" when they fail (ie smacked a rock) on a mountain bike ride .... and suddenly you have to create a single speed bike to limp home :-/
just when you thought the thread couldn't get any worse...![]()
That test would be thwarted by the freewheel.Actually, one way of reproducing the effect of the dérailleur being above would be to change gears while backpedalling. (Can you borrow someone else's bike for the trial?)
