Cyclopathic
- Leicester.
I may have asked this before but I don't think anyone could tell me.
I hadn't noticed it on other rubber products.rubber always smells funky
Ah! Memories.
Ah! Memories.
My introduction to fetish wear, although I didn't realise it at the time, putting on the WW2 gas mask that still lay about the house in my early childhood.
Thanks. I never knew that about the light vessels and the funkified air. I'd have thought it would be a fairly straight forward matter to install some very rudimentary ventilation in them though. But I'm not a marine engineer so I could be wrong.A combination of stale air, dirt and oil which has been in those tyres for a long time are the causes of the funky smell. The rubber plays a bit of a part in it but not as much as the rest, and especially not as much as the air being old.
If you completely replaced the air every couple of days it wouldn't smell as bad, but you normally only top it up between rides and so it isn't replaced. The same sort of thing happens on things like ships, take for example the Channel light vessels, they never are manned except for maintenance and so when the crews go onto them they have to carry protective gear and air meters to check how stale the air really is. It is all trapped in a single space without proper ventilation or circulation.
