balzer69
- Lincolnshire
where people can post gear deals that are particularly good. It would have to be policed to prevent spammers I suppose.
balzer69 said:where people can post gear deals that are particularly good. It would have to be policed to prevent spammers I suppose.
porridge said:Yes please, bike gear is so expensive
bonj said:most should be expensive, 'cos it's good kit.
With the exception of some things, it's not possible to make a product that will do the job correctly, and last, for a cheap price.
Bargains should be used discriminately.
balzer69 said:'cheap' is not the same as 'bargain'
Bigtallfatbloke said:They are V good jackets and do the job. Just be a little careful of the zips. For the most part they are fine but they have a reputation for 'sticking up' sometimes. Mine have been ok for two years now, except the chest pocket zip which got stuck, so in typical blokish mode I pulled it to hard and now it doesnt work so good!
So I put a drop of chain lube on the zipper and things now work smoothe as you like!
At night they light up like blackpool tower, you can test it yourself with a flash self timer photo...sad I know but i had no friends with cars...![]()
porridge said:Sorry I disagree to a certain extent, its because the retailers know its a specialised market and as such they tend to excessively mark up the prices.
I also disagree about bargains being used discriminately, bargains don't have to be poorer quality, some very good quality gear is often sold off as clearance lines.
Its a well known fact that most cyclists are high earners, which probably explains the total disregard for the cost that exists for many of the forum members.
Quality by all means, but cycle retailers need to stop ripping off the cyclist.
Source please?porridge said:Its a well known fact that most cyclists are high earners, which probably explains the total disregard for the cost that exists for many of the forum members.
