MattHB
Proud Daddy
- Deepest darkest Dorset
GF and I have a specialized crosstrail each, same model (v-brake 2011) from same shop, same time.
A weird thing is that when we got them the braking area on the rims was painted black. As I've now done some miles this is no longer the case and the rims are heavily scored from the standard brake blocks that had bits of metal in them. The other weird thing is that where the rims formed when the 2 sides come together there is a ridge, which is obviously bad for a block wizzing past.
Did we have the rims for the disc version fitted? The hubs are normal non disc hubs, no carriers are on them for any rotors.
Im going back to the LBS Saturday with the bikes so they can look, but I wouldn't mind knowing before hand what the deal is.
Am I also right in thinking that on proper v-brake rims the braking area is likely to be of a tougher material than one not designed for them?
Cheers.
Cheers.
