rusky said:Are you still after a copy of XP? I'm sure I have an OEM one here. Not machine specific either.
2Loose said:Regarding Dual booting, don't bother unless running a virtual machine has already been tried..
Get a copy of Virtual Box (free) and run that directly from within Windows. That way you can run a proper copy of Windows XPMeNT9895Dos etc. from an icon on your desktop, either full screen or inside a window.
You will of course still need a proper copy of whatever operating system you want to use and it will not mess about with bootloaders and therefore reduce the chance of breaking the existing OS.
numbnuts said:This stinks Microsoft have bought out windows 7 and it is "not fit for purpose" as it can’t use old software, if that’s the case there should be a warning saying so on the box/computer![]()
hackbike 666 said:Not a effing again?
Had this after Windows 98 and it still goes on.
Im still on XP...I tried Vista and hated it...plus nothing worked and it was memory hungry...never tried se7en.
2Loose said:Beanzontoast, if this idea is specifically for graphics intensive stuff (your flightsim for example) then I don't think the XP in a virtual machine would give as good performance as a proper dual boot. Reasoning is that the vm creates a virutal graphics adaptor which tends to have less functions than a gaming capable gpu. ATI/Nvidia drivers are useless in a vm.
Still, it costs nothing to try it out and see if it is acceptable...
beanzontoast said:I've looked at a couple of You Tube vids about Virtual Box since yesterday and have come away with the same feeling. Still might give it a try for fun just to see how other apps run on it.
... and meantime, still looking to find a full legit version of XP Pro or Home from somewhere without it costing an arm and a leg. Ever the optimist!![]()
classic33 said:XP Pro Upgrade gives a full working version. even from Windows 95.
