You IP Address Has Been Banned
spen666
I suddenly get this message when going to the home page on my laptop. Connected to Internet via Community Fibre, but using my phone also connected to the Internet via same router, I can access the site.
Any reasons why my IP address had apparently been banned
User state: Valid
No matching spam trigger logs were found.
Glasgow
I'll investigate.
Has @Scoosh been tampering with the IP addresses again?? :laugh:
I'm moving this to site support, for easier communication with Spen and because I think I hopefully sorted it.
spen666
spen666
Hello @spen666, I've moved your contact us to site support.
I have checked some of your log ins.
Have you got VPN enabled on your laptop?
Some of your log ins are from a VPN, a quick check shows one the generated IPs is on a spammer's database.
Thanks Pat - yes, I have discovered I had a VPN installed - not sure how or why that came about. I have removed it and uninstalled it.
Explains why my phone was not blocked but my laptop was.
Thanks
Glasgow
Well, if you need the VNP app on your laptop, just remember to set it to the UK when accessing CC, or switch it off.
I made the same mistake on my tablet, VPN was set to Germany, the Channel 4 app rejected me :laugh:
Chromatic
Gloucestershire
I’ve had the IP address banned message here quite a few times in the past and been unable to open anything, leave it a while and all works again.
I do not use a VPN.
Glasgow
I do not use a VPN.
That could have been because your IP was under a spammer's IP range, so to speak.
Sometimes we get a lot of spammers from the same area, then we ban the whole area.
It's mostly abroad zones, but it has happened in the UK too.
After a while we get complaints, so we restrict the banned IPs zone.
Here is a better explanation.
R_nger
FWIW… I am also getting the “IP address is banned” on my iPhone, in Google Chrome, but not in Safari
nogoodnamesleft
User state: Valid
Community Fibre has started using a CGNAT. You may or may not be set through one and if you signed up or renewed recently then you are very likely to be running through one.
They are doing it because they don't have enough IPv4 addresses for everybody so use it for IP sharing ie there will be a fair number of others on the same IP address.
This has several issues for normal consumer internet use:
Chances of IP address getting a bad reputation is far higher as each has far more people using it.
and, many servers detect connections through a CGNAT and impose additional security checks/constraints. VPN is another form of IP sharing so same problems apply.
Way to get out of going through a CGNAT is to get your ISP to give you a fixed IP address but most would make a charge for this.
Going through a CGNAT does impose other constraints but they don't affect most users (eg if you are hosting some server).
