And.....
Bike-Eye Review pt2
Friday, December 10th, 2010 by Mick Allan
Bike-Eye designer Tony McGuiness’ response to my previous post contains some insightful comments so I reproduce his email in full:
Hi Mick,
Thanks for the blog post, your opinions mirror (sorry for the pun) mine almost to a tee. I have become so reliant on the mirror and use it in a similar mode to that of a motor cars interior mirror in that I check behind in good time before I need to make a manoeuvre and I’m almost always aware of what type of vehicle is bearing down on me if it’s a car, large van, bus or articulated lorry. Each type of vehicle can present different dangers to cyclists. With the information to hand it allows me to manoeuvre around the road safer, “fore-warned is fore-armed” as they say! I could count on at least 100 pair of hands the amount of times I’ve heard cyclist say “they would rather not know what is behind them” personally I just can’t get my head around that mentality.
Safer cycling with added rear view awareness Further to your remarks on panniers I have attached information lifted from our web sites FAQ page:-
Can you use Bike-Eye when you have panniers and/or large saddle bag fitted?
A full touring set up with rear panniers and a large saddle or top bag will definitely block the line of view through the Bike-Eye mirror. It’s possible to acheive a view above panniers in some instances, for example, if the panniers are low slung and the mirror locating point on the frame was high enough.
If you are using a single pannier bag this could be located on the opposite side to the mirror leaving the line of view clear! On most frames Bike-Eye can be mounted on the cross bar if the frame size and rider height are appropriate, i.e. there is a clear viewing pathway below the riders thigh! It’s best if you can run a line along the frame from mirror fitting location to the panniers to see if the viewing angle would be above or below the top area of the panniers.
Wide saddle bags usually get in the way, narrow saddle-stem and seatpost fitting bags are an alternative and usually allow a clear viewing pathway!
Regarding Trailers:- Bike-Eye can some times be helpful in keeping an eye on little ones in trailers or tag along bikes.
Other user benefits:- Cyclists who wear glasses have peripheral vision problems and need to turn much further to view behind due to the fact they look out of the side of their glasses as apposed to through the lens centre, Bike-Eye is hugely beneficial for them as well as riders who have lost the sight of an eye especially the right eye on UK roads and cyclist with neck or spinal limitations, physical or age related.
The fact that the Bike-Eye offers Increased riding enjoyment to thousands of cyclist who are now in tune with their cycling partners whereabouts on a regular basis I find hugely rewarding.
Best Regards Tony
@ Bike-Eye
