Zwift Chat
Whorty
Gets free watts from the Atom ;)
Wiltshire
I'm thinking the same how old is the pc/laptop how much memory does it have
It's a quite old laptop. Could well be it can't handle the high processing requirements when lots of other avatars around. Think I just need to avoid busy courses.
kipster
Hampshire
Reduce the graphics settings in zwift, that should make a difference
Whorty
Wiltshire
New laptop, new laptop!
But I only use it for cycling, cat videos and porn, and it works perfectly fine for the latter two uses :tongue:
Norry1
Warwick
My bike is a long frame, so I have to remove the hanger as well, its so close to the edge of box. I fit a wood spacer between forks and place thin sheets of wood under crank so teeth doesn't get knocked. I've a method to taking pedals off. If you take both pedals off from the crank side you undo both with anti clockwise rotation. :biggrin:
I use the methodthatyouundob
Tried raising a support call?
