I'll be on a race about 7 too tomorrow and also go for cat C.I've put my name down for cat c is this where most of us will be?
It's 8, as there is some down hill i should be ok if i can get in a good group I'm praying the start is not crazy.are we all going in c then ? - we will get bumped ! shouldnt we just go b and not worry about it ? and is it 7 or 8
Just noticed that, yes it's 8.I won't be on then, too late for me.It's 8, as there is some down hill i should be ok if i can get in a good group I'm praying the start is not crazy.
having not done so many races as you lot - what do you suggest i do ? if i can keep up with you lot then the wtts will be too high for c - even if i come nowhere ( if you havent noticed - i am a skinny mini !) if i was to join b would i set off the same time as you ? or should i just go for c and get bumped if i do go over ?It's 8, as there is some down hill i should be ok if i can get in a good group I'm praying the start is not crazy.
C normally goes off earlier than B. If you go B you'll catch most of the C's by the end if you stay with the lead B riders.having not done so many races as you lot - what do you suggest i do ? if i can keep up with you lot then the wtts will be too high for c - even if i come nowhere ( if you havent noticed - i am a skinny mini !) if i was to join b would i set off the same time as you ? or should i just go for c and get bumped if i do go over ?
It's a fluke mate!I changed my settings this evening to instant power and I found it a lot easier to stay in a group and is felt a lot more responsive. May of been a fluke, will try it again tomorrow.
