What’s stopping you dropping more weight Andy? Decided you’re happy where you’re at or you’ve found your ‘natrural’ weight? if that makes sense. Either way... on flattish TT’s if you can get a good postion worked out on the bike, you should be a real force to be reckoned with! Have you got the TT rig set up yet mate?
Weight is probably around natural to a little under. 91/92kg is sustainable without too many sweeties
I have done the base settings which allow me to be comfortable, not crick my neck (very important to me). I even got an expensive TT helmet-very cheap being ex demo. I need to set the bike back on the turbo and try and do 20 min interval to gauge power and comfort properly. The early signs were positive, power was very easy to make with having hips much further forward and open, so much so I need to keep a check on them as I was producing 30w more than FTP, breathing needs to be checked. I would blow up outside, I don't have a pm on this bike. I will probably sell my Ultegra Stages and get the FSA one for the bike. I haven't sorted gearing, but found I can get a carbon chain ring made relatively cheaply, anything upto 60T
