Hi,
I have recently bought a CycleOps 2 fluid trainer and would like to get onto Zwift however I’m a little unsure as to what kit I need, ive done a little bit of research.
I have an old PC in the loft which is about 10 years old & a lap top which is also reasonably old which never gets used would these work or would the software be outdated, unfortunately my daughter has my Mac book at university so won’t be able to link to Ant+ however I have about 4 iPads from mini to air which would work on IOS however I’m totally confused with what Kit is compatible and what’s the reliability like on Bluetooth? I’m thinking of getting a Wahoo speed and cadence sensor which I believe is Bluetooth compatible, would this be the best option or get a cheap PC or laptop with the correct software.
Any recommendations would be helpful.
Thanks
Peanut
Thanks
Peanut
. You could then use these and iPad. Zwift will treat the trainer as a (virtual power) trainer, apply a power curve with the help of the speed and cadence signals. Should work quite well but have no variable resistance that a Smart power meter trainer eg Kickr, Neo, Elite.
