classic33
Leg End Member
What's your prisoner number?Oh god someone shoot me.
FTFYIf the jumper was from Yorkshire, he proably jumped because 10p fell off the windowsill, and he went after it. He wasn't really tryjng to comit suicide.
Muzzle velocity varies, the man would be at terminal velocity.The bouncy thing at the bottom didn't belong to him. The other stunt man had deflated it and loaded it on his truck.
PS it is impossible other than by luck to have hit him. The bullet would be travelling at below muzzle velocity , which is? The jumper would be falling at? But accelerating as he fell so he would be travelling at?
FTWY
On which he changed his mind, albeit a bit late in the day.Then it further reinforces his initial suicide attempt.
I'll have the shovel!It works equally well if its a welshman, irish man. As for the English, well take your pick
So you didn't even die once. If your resuscitated you never died. Stop exaggerating.Popped mi clogs on the operating table, causing the operation to be stopped in '95, and I'm posting.
Heart failure main cause, as given on the records.So you didn't even die once. If your resuscitated you never died. Stop exaggerating. The I hit the ground so hard once I lost lost consciousness and stopped breathing. I restarted without any help from the medic. I didn't die neither did you.
So...jumping caused his death not the bullet?Muzzle velocity varies, the man would be at terminal velocity.
Then he becomes his own killer and the whole world implodes lol.On which he changed his mind, albeit a bit late in the day.
I spoke to a resident of a tower block shortly after someone had jumped from the top.
"I saw him go past my lounge window," said the resident. "I knew something was up because I live on the tenth floor."
You didn't die, as given in the records.Heart failure main cause, as given on the records.
