Bromptons and other small wheeled bikes run through sprockets, especially small sprockets much faster than 700c bikes. It would be good to be able to replace them individually.
What is the point of choosing 11-14-17 cogs? What is this combination supposed to achieve? I am using 12-14-16 which gives 16% of gear jump optimal for BWR as 1.57^(1/3)=1.16. With 14/11=1.27, i.e. 27%, it is just as bad as with 2 sprockets. I do not see this choice doing anything either for BSR. Am I missing something?
I have 12-14 -17. So just a 3 speed. I like having a low for climbing. I may replace 17 with a 19. Once your over a hill you can go directly to high. You don't need the in between gears.
We like to provide as wide gear range as possible yet compatible with as many stock parts as possibleI have 12-14 -17. So just a 3 speed. I like having a low for climbing. I may replace 17 with a 19. Once your over a hill you can go directly to high. You don't need the in between gears.
I don't think this will work on the BSR because even 2 sprockets won't work. The driver on the BWR is made for 2 so it should be ok for thatWhat is the point of choosing 11-14-17 cogs? What is this combination supposed to achieve? I am using 12-14-16 which gives 16% of gear jump optimal for BWR as 1.57^(1/3)=1.16. With 14/11=1.27, i.e. 27%, it is just as bad as with 2 sprockets. I do not see this choice doing anything either for BSR. Am I missing something?
That does look nice.Looks nice with hub 40g
They are made in Sturmey Archer (now in Taiwan / SunRace) , My impression is you can change the free hub body to the shimano 9 splines spec. Let me check.I actually called my favorite Brompton shop to see if the two sprocket driver that comes on BWR hubs could be bought separately for my BSR and they said they couldn't get the driver that way and had to buy the whole hub. I assume Sturmey Archer makes the Brompton 1/2 speed hub but don't know for sure. Anyone know who makes it?
