29er Tyres - Hybrid tyres
Overconfidentii Vulgaris
That looks good (rim size permitting). The Vittoria tyres mentioned above look like a good suggestion too.
albion
Gateshead
So what?
Means you should be safe using 35mm and likely even 32mm.
M
Madboy
Hi all
Got my new tyres and inner tubes and all is fitted. Like I said am relatively new to all this. Now the minimum pressure is 60psi and the max is 90psi. I weigh 12 stone 12lbs and use the bike for going down canal paths and on cycle paths. What the recommended pressure for cycle paths and what's the recommended pressure for canal paths on my mountain bike?
M
Madboy
Many thanks. I didn't know if I had to go to 80-90 or something. Brilliant so I can use same pressure on canals and cycle paths. Once again Phil many thanks for your help. Oh and I didn't realise that the tyres were going to be so thin lol
