cyberknight
- Land of confusion
I am interested in converting my drop bar carrera subway to 700c wheels as the stock wheels weigh ton .
I stuck a road wheel in the front just to see clearances and apartfrom the disk brake caliper which im guessing is because the wheel is not dished for disk brakes (?) their was plenty of room.The back i havent tested as i have not got a 135 mm hub wheel .
I assume that the 700c wheels that a re set up for disks would slot straight in without having to alter the brake calipers ?
I have read that fitting bigger wheels raises the centre of gravity but i cant see how as you have skinnier tyres your not that much higher ?
Or would it be easier to get a lighter set of 26 " wheels ? would only be £100 for the set which i know isnt a lot .
