My question is .Can I up date my 5 speed block on my old TI Raleigh 531 replica bike , With modern equipment ie campag 10 speed block . What do I need to change
Thank for any help
I'm assuming a lot about what you do or dont know Dave, so forgive me if i state the obvious.
The 5 speed wheels you have will have a screw on block. Modern wheels/hubs capable of taking a 10 speed cassette are wider to accomodate all the extra cogs. You need new wheels, then you need to spread the frame (cold setting is the term) to accept these wider hubs.
You of course need new shifters, and these ARE expensive. new rear derailleur, new crankset/cranks because the chain is much thinner on 10 speed transmissions, it wouldnt work with you existing chainset, new chain, and probably a new BB for the cranks.
I upgraded mine to 8 speed with Sora shifters, it all works beautifully, but it still costs an awful lot. Upgrading to 10 speed, i wouldnt even like to consider it myself. As Hacianda says, its maybe better to leave it original.
One option, if you're considering this because you dont have enough gears....is it a single cog on the front or a double ?
If its a single you could fit a double chainset/cranks on the front, new chain, front derailleur and a pair of double friction shifters on the downtube. You'd probably pick up those parts quite cheaply on
ebay. I did the wifes runaround, its moderately straightforward.
