knobblies have a lot more rolling resistance with the road, some claim the difference between knobblies and slicks can be up to 5-6mph!
also knobblies tend to crack on the side walls when ridden on road so be careful
Cheers Ed
how wide?I manage about 36mph on a couple of hills around here on Conti CXSpeeds. Compact gearset too.
I have just made the change from slick tires to knobby tires and the change in the comfort the knobby gives me is amazing when I hit bumps or rough patches on the road on my commute to and from work
Have you made the change ? if you did let us know about it
how wide?
they are only slightly knobbly though i was on about the difference between real knobbly proper MTB tyres and road bike skinny tyres
Cheers Ed
i see a CX type tyre, could be good if we get a hard winter to chuck on my cummuter for example35c tyres. They have a diamond tread instead of smooth central slick section:
http://www.conti-tyres.co.uk/conticycle/ti cyclocrossspeed.shtml
Surprisingly good on a stop-start acceleration, but as said above cornering is.... different.
Cheers Ed
less grip from more tread??? am i missing something here?The last thing you want in cold, wet, icy conditions is even less grip from excessive tread IMO. You're not going to hydroplane on a bike, so tread is only needed if you're heading off-road.
