Fab Foodie
- Kirton, Devon.
So what non-cycling helmets do you get to wear?
Here's one from me ....
Don't drop it then.when a stainless pipe coupling in a manufacturing plant that can be removed for cleaning gets dropped from a height it can be fatal without the Hard Hat. with the proper head protection it hurts but is generally survivable.
when I work on a roof I have to wear one as there is a risk something could fly across the roof from another area.
Once went to Immingham docks to pick up a 40ft container weighing 29 tons (I think is was) nearly wet myself when they said I had to wear a hard hat in the cab, like that was going to protect me if the chains snapped on the way down from 100ft.when a stainless pipe coupling in a manufacturing plant that can be removed for cleaning gets dropped from a height it can be fatal without the Hard Hat. with the proper head protection it hurts but is generally survivable..
That should come with a health warning!
But it's a box ticked.Once went to Immingham docks to pick up a 40ft container weighing 29 tons (I think is was) nearly wet myself when they said I had to wear a hard hat in the cab, like that was going to protect me if the chains snapped on the way down from 100ft.
Alan..
yeah sometimes its a bit sillyOnce went to Immingham docks to pick up a 40ft container weighing 29 tons (I think is was) nearly wet myself when they said I had to wear a hard hat in the cab, like that was going to protect me if the chains snapped on the way down from 100ft.
Alan..
Injuries sustained from a stale pork pie can be quite severe.
