Pale Rider
I have a serious question about toilets.
There are two in my static caravan, both basic white flush toilets with a low level cistern, fed from the mains.
Problem is the water level in the bottom of the pan goes down when left for a while.
This has only started happening in the last year or two.
The toilets function correctly in other respects.
Lowering water level is no problem during the season when one is in and out of the van regularly.
But shut down time is approaching when the caravan will be left for weeks at a time.
If the pan level drops below the start of the U-bend, foul air gets into the caravan - not very nice.
A lesser risk, but still present, is Roland can get through an empty U-bend more easily than one full of water.
Any comments - even serious ones - welcome.
