Adjustable stems - yes or no?
robjh
robjh
Sorry to hear you have back problems Rob. I went through that a while ago a raised and short stem helped me get through it so good luck GWS.
Thanks. The worst of the problem was last year and I'm mostly over it now, but longer or faster rides on this one bike can bring it back on. It's the Giant I had on the rides in Wales we did together, I rode it happily for years until one day in July 2016, but anyway that's just the history. My other 2 bikes don't cause these problems (unless my back is already inflamed from the Giant) and the thing they most have in common is smaller saddle-to-handlebar distance and height difference, so this is the obvious thing to try on the offending bike.
Globalti
I bet 99% of those get fitted then never adjusted again. It's an inelegant, heavy, possibly unreliable and certainly over-elaborate and over-expensive solution to a simple problem, which is normally solved by adding and removing spacers from under the stem. The modern threadless stem is a simple solution for easy DIY adjustment although admittedly not as elegant as a traditional quill stem.
robjh
robjh
I'm already at the top of the steerer tube. Would you add spacers so that the stem sits partially above the steerer tube itself, and if so how far is safe?
The other option of course is a steerer tube extension of some kind, say this
or this
What does the CycleChat community think of them?
Sharky
Kent
Just checked and mone os a richley
I am in the 1% group.
Originally set up my bike as follows:-
But two broken collar bones and one fractured pelvis later, can no longer keep that low position and the stem was moved upwards to a more horizontal position.
Globalti
or this
Ugh. If you need to fit that there's something fundamentally wrong with your bike size or your position.
Red17
South London
My Ridgeback hybrid came with one. I've never bothered adjusting setting of it but have spent hours trying to stop it creaking without any success so far.
clockworksimon
England
I fitted a Zoom version of one of these to my road bike as I didnt have enough steerer tube to get the stem any higher. As my back improved over the year, I have lowered the stem on the extension tube so there are no longer any spacers under it. The bike looks better without the extension but thanks to being able to get more comfortable I am riding every weekend, going further and faster which is more important than looks. I will just point out that raising the bars above a certain point will require you to fit longer gear/brake cables.
clockworksimon
England
I presume you have tried spraying WD40 or similar into the joints? This has worked for me when creaks continue despite tightening up.
Red17
South London
Sprays, oils, greases and different torque settings. Still creaks though.
clockworksimon
England
In addition to experimenting with stem height and angle to ease back issues, I found that even minor adjustments to bar angle and seat height/angle/fore-aft position also helped.
My Zoom stem extension worked fine, creak-free whilst riding past people pushing their carbon fibre exotica up Mow Cop in the CW125 in September. Without the more comfortable position I wouldn't have managed more than a couple of hours.
Salad Dodger
Kent Coast
I have had one on my mountain bike for several years, with no problems at all.
Having used it, and adjusted the stem several times until I got a comfortable set up, I suppose I could try to find a fixed stem with exactly the same dimensions of rise and reach. But, to be honest, that's too much of a faff. I am happy to go on using the adjustable stem unless it falls to bits, which I have no reason to believe that it will.
