That's what I've heard but unfortunately I don't have a dremel and my hacksaw is broken.If you have a Dremel, use the cut-off wheel through the slot on the grip.
What is one of Those ??Try a Torx fitting.
Is a star shaped hex socket the same thing as an Allen key ????It's a star shaped 'hex' socket. You may have some in your socket set(if you have a socket set). You tap it into the hex slot, and there may just be enough purchase to undo it.
Is that the only way ??I'd also try a Torx but substitute the word tap above with smack
Shaun
When I put the hex in the bolt it's just spinning. But the bolt (where it should be hex shaped) is round but the Allen key is fine.Stripped to means the thread has gone and the bolt just turning, in which case the torque will not work.
Now if he means the hex has rounded out it may well work.
