Alan Farroll
Going to buy my first mountain bike. I notice some are aluminium and others alloy. Is aluminium heavier? what about an alloy frame rusting? What's it an alloy of?
Thanks in advance
Alan
Thanks in advance
Alan
Yes. You'll see a couple of different aluminium alloys in today's market, 7005 and 6061. 6061 is an older type of alloy, and needs a particular hardening process to finish it. It contains magnesium and silicon. 7005 is newer, and can be air cooled. It's denser than 6061 which means stronger for a given tube wall thickness. 7005 tends to be found on more expensive bike frames and can be butted (material removed from the middle where it isn't needed, and left in at the ends where it's welded to other tubes. ) Butted tubes tend to be lighter than non-butted. 7005 can be hardened in air, and tubes tend to have sculpted or swoopy shapes allowing the tubes to flex more than straight tubes whilst still retaining strength where it's needed. Straight tubes can be very stiff, fine for transferring power through the frame, but aluminium alloys are stiff to the point of harshness, so shaped tubes give a more comfortable, compliant ride.Okay. Thanks this is becoming clearer. So if a manufacturer says the frame is for instance "ALUXX-Grade Aluminium" or they simply state in the specifications of a £600 mountain bike that it is Aluminium, then it is not really pure aluminium but an aluminium alloy!!?? And also, if the specifications state that the frame is an "Alloy" then it also is an aluminium alloy??!! Is this correct?
No, a steel alloy is a different material to an aluminium alloy. All metals can be Alloyed even Gold to give 9ct. 18ct and 22ct versions.Okay. Thanks this is becoming clearer. So if a manufacturer says the frame is for instance "ALUXX-Grade Aluminium" or they simply state in the specifications of a £600 mountain bike that it is Aluminium, then it is not really pure aluminium but an aluminium alloy!!?? And also, if the specifications state that the frame is an "Alloy" then it also is an aluminium alloy??!! Is this correct?
However, in bike marketing terms, a steel alloy frame would be billed as steel or chromoly. Alloy is generally used to denote an aluminium alloy. So if @Alan Farroll is in the market for a new bike, he can be reassured that an "alloy frame " is going to be an alu alloy. Very few entry level MTBs are made of steel alloy, and if they are, the marketing will,make sure you know it.No, a steel alloy is a different material to an aluminium alloy. All metals can be Alloyed even Gold to give 9ct. 18ct and 22ct versions.
