I also have a app called clean master, which does a good job of deleting all the junk files, and from that program you can disable of lot on apps you will never use (you can' delete them as they are factory installed, but disabling them saves power)
You can delete factory installed apps if you 'root' your phone. First thing I did with mine. BUT be careful if you decide to do it, there be dragons and you can stuff your phone entirely.
Battery save apps; wot everyone else says. They don't do anything (other than chew battery) that you can't do yourself manually.
If you are running an older version of Android then it's worth using a task manager. If you're running a newer version of Android (I'd suggest 4.1 or above, since Project Butter), then the operating system's own task manager is far more sophisticated. It may appear as if an app is running if you use the multi-tasking/recent apps list, however most of them (especially if your phone is running out of resources) are in a suspended state.
Thanks guys, I didn't believe all the nonsense that the developers wrote about them, now at least I don't have to waste my time finding out for myself.
