Drago
- Suburban Poshshire
Because they don't ride bikes of any kind, and don't have Wives in wheelchairs?
What on earth is that!? A whippet-lean roadie with matching bike might be able to squeeze through it, but everyone else would have trouble. Also, it doesn't cater for larger bikes, e.g. tandems, bakfiets, recumbents, etc. Whoever designed that obviously does no cycling.Manchester leading the way
The barriers on the Fallow field loop never seemed to be a problem for me but I only ride a 'normal' bike. The ones that really wind me up are the tall ones that lean inwards to narrow at the top. These are a total menace and are not even wide enough for my shoulders to fit through, never mind the bike handlebars!
This kind of thing - View attachment 152980
Although there doesn't seem to be any set standard on the width and some are worse than others. I have actually felt as if I have slightly jarred my neck and shoulders on some occasions after negotiating/man-handling me and bike through some of these.
Not THE SAME but SIMILAR - measure the diameter, width and so on. People really did use some motorcycle handlebars on bikes. See, for example, https://hadland.wordpress.com/2012/06/30/did-brits-invent-the-mountain-bike/You really have no clue what you are talking about have you![]()
These are the same as on your bike are they?
...writes someone who seems to be reading "the same" where I wrote "similar"?We're not arguing with you, we agree with you, are you actually reading what we type or is there a hidden agenda we don't know about
It isn't. You're quite free to do whatever agility tests you want between consenting adults off the main routes, but the context of this is removing such torture devices from the Sustrans NCN.Since when has my cycling preferences been restricted by, or had to conform to some idealogical standard dreamt up by SUSTRANS?
I don't see that type being a barrier to wheelchair access, not like the type I pictured, but I would have to consult with affected user groups to confirm this before I would ever elect to install one.It isn't. You're quite free to do whatever agility tests you want between consenting adults off the main routes, but the context of this is removing such torture devices from the Sustrans NCN.
They do consult... and then install the bloody things anyway, in my experience!I don't see that type being a barrier to wheelchair access, not like the type I pictured, but I would have to consult with affected user groups to confirm this before I would ever elect to install one.
When you say "nothing" do you mean you had no reply? Are you sure your reports are getting through? Log it on www.fixmystreet.com as that usually hits home.How about this one, been like this years, I've contacted the LA and also Sustrans - nothing. Not that bad if you know it's coming, but what about first timers?
Does the gate open?How about this one, been like this years, I've contacted the LA and also Sustrans - nothing. Not that bad if you know it's coming, but what about first timers?
