Anti-motorbike barriers to be removed from National Cycle Network
Inertia
I feel like I could... TAKE ON THE WORLD!!
I don't see that type being a barrier to wheelchair access, not like the type I pictured, but I would have to consult with affected user groups to confirm this before I would ever elect to install one.
This is one similar to the ones I have to navigate, the shape for bikes doesnt allow some bikes through (No chance with panniers), good luck getting a wheelchair through.
Deleted member 26715
That's evil worse than the ones I have to go through, are they just on entry/exit or along the track as well
I like Skol
A Minging Manc...
That is a piece of engineering. Actually, I take that back, it is a piece of fabrication with very little consideration to engineering, design or purpose. It is a truly horrendous item and I suspect a result of a situation where the fear of the crime is massively over shadowing the possibility of the crime!
  • Like
Reactions: mjr
Inertia
Its on the track, you walk down steps, under the bridge and are hit with that. Unlike the pictured one there is a locked gate next to it whch runs up to the canal.
shouldbeinbed
Rollin' along
Manchester way
Manchester leading the way :okay:
The barriers on the Fallow field loop never seemed to be a problem for me but I only ride a 'normal' bike. The ones that really wind me up are the tall ones that lean inwards to narrow at the top. These are a total menace and are not even wide enough for my shoulders to fit through, never mind the bike handlebars!
This kind of thing - View attachment 152980
Although there doesn't seem to be any set standard on the width and some are worse than others. I have actually felt as if I have slightly jarred my neck and shoulders on some occasions after negotiating/man-handling me and bike through some of these.
Those sort are a PITA also locally those annoying ornamented blocks in the ground by the supposed bike cutout at the entances to Clayton Vale.
Inertia
Had a nice surprise this morning, not. The one I talked about earlier is the only one I have to dismount for until today. There is a similar barrier further back on the towpath but it doesnt reach to length of the path so there was a gap to the side of it I could ride through instead of dismounting. The operative word being was..someone has made an addition. :cursing:
mjr
Non-reflective wood? That's only a matter of time before someone crashes into it in the dark hard enough to break it.
Jody
Stubborn git
:whistle:
  • images?q=tbn:ANd9GcTh1pKAdw4zmdRFX5zopbg2VJ-ms0nFnK5JZ-kEdxrlmxQc8O688g.jpg
byegad
NE England
I gave up on Sustrans some years ago. As a recumbent trike rider, due to intermittent balance issues, the barriers made most paths in my area impassable. Add to that 'surfaces' that can be a quagmire and signing that is woeful, and I'm now using those nicely (Well mostly nicely.) tarmacadamed cycle paths, beautifully signed and directly routed things called roads!
Experience of being a Sustrans Ranger tells me the anti motorcycle barriers are easily circumvented by yoofs on motorbikes by smashing down a couple of fences and mmoto-crossing an odd field, not something open to most cyclists and a big no, no for a recumbent trike rider!
As for County Durhams experiment in barrier removal, I'd guess the people objecting to it were the same ones who walk dogs on 10m strings on the ex-Railway mixed use paths that are a feature of the Durham area. They also objected to cyclists using the Spennymoor-Bishop Auckland path and wanted barriers put in to keep cyclists* out.
*N.B. Cyclists, not motorcyclists.
Inertia
heh, well I cycled in this morning and couldnt see it as I rounded the corner, when I got close it woudl appear it had a crash with a saw and a spade over the weekend :laugh:
