Anyone still using 23 C tyres?
figbat
Slippery scientist
My road bike came with 23c - I have replaced them with 25c but that’s as big as it’ll take. In fact even with 25c tyres it’s a squeeze to get the rear wheel on as the tyre fouls the seat tube when at the very front of the QR dropout.
Luckily it makes no difference on the turbo!
FishFright
More wheels than sense
Nope. Grip doesn't work like that. F=MuN where F is the available friction, Mu is the coefficient of friction and N is the downforce. Note that area does not feagture. This is THE most misunderstood fact of traction.
That's why racijng cars et al still run on very narrow tyres .....
Grip is not the same as the coeffincent of friction , it's way more complicated and includes stiction and momentary chemical bonds amongst a soup of other variables.
Loch side.
By definition friction is not the same as the coefficient of friction. The latter is a dimensionless number and the former is expressed in Newton. Stiction is another name for static friction which is just one of the two types of friction.
Throwing jargon into a salad and dressing it up as complicated won't cut it.
I'll say it again. The friction available from a 23mm tyre is exactly the same as that from a 40mm tyre or any other dimension you'd like to come up with.
Bristolian
Bristol, UK
Can only go up to 25mm on Allez (2008 or 2009), and that's ever so close to rubbing the seat tube. No chance of a mudguard in there!
Have got a more comfortable 32mm on the gravel bike, and still have room for full mudguards.
Mine was manufactured in September 2010 and you're right - no room to get a mudguard between the fork crown and tyre at the front but I can just get my slightly modified SKS Raceblade Pro between the seat stays and rear tyre at the back but no chance of getting it between the seat tube and rear tyre.
One of the reasons I'm looking at a gravel bike is to get wider, more comfortable tyres :okay:
Loch side.
Mod Note:
We are getting a wee bit OT with the friction argument, please stay on topic.
Cheers!
Pat, some people think the meaning of life can be found in carburettors, but they're wrong. It is all about friction.
Seriously, I think friction is a relevant element of this debate, since someone upstream said wider tyres are less slippery etc.
andrew_s
Gloucester
I ditched 23C for 25C about a decade back.
I ditched them in 1995 after pre-PBP test runs/qualifiers. I was after comfort, but came to the view that they were just as fast provided you got a decent model.
I was on 28, as the biggest that would go under dual pivot brakes with mudguards, until I got a disc brake bike, and immediately changed to 35.
lazybloke
Ginger biscuits and cheddar
Leafy Surrey
Yep, I supplemented my Allez with a Croix de Fer. The geometry is much more comfortable, and the mudguards and wider tyres are good, but the bike is noticeably heavier and significantly slower.
So when feeling sporty it's the Allez. Otherwise it's the CdF.
But the Allez kills me on long distances, so I reckon there's another bike out there for me. Was tempted by a carbon Synapse 700 recently...
