Are waterproof overshoes worth using?
BigAl68
Bath
Yes they do to a point. If you really want dry feet it's winter boots. I also then use the overshoes when they get put out as my shoe of choice just like @ACS
outlash
also available in orange
Have used overshoes in past winters and while they do the job, they're flimsy and I end up buying 2 or 3 pairs over winter. I've just received a pair of Northwave Celcius boots in the hope that in 2 winters, they would have paid for themselves by not shelling out for overshoes during the winter months.
FWIW, the Castelli Diluvio 'shoes have a longer leg section which helps a little more with keeping water out.
buggi
Bird Saviour
Solihull
No such thing as waterproof. Go for neoprene overshoes which will keep your feet warm both in cold and when wet. And yes they are very worth it. They work down to minus temperatures.
Deleted member 1258
I've used them in the past and found they're OK for short trips but not on longer trips.
mybike
Grumblin at Garmin on the Granny Gear
Gave up on overshoes about 3 winters ago. Bit the bullet and purchased a pair of boots. Now use overshoes to keep my boots clean not as protection against adverse weather.
Shut Up Legs
Down Under Member
Overshoes mostly work. To force them to completely work, I recommend applying large amounts of waterproof gaffer tape just where the top hem of the overshoes meets your calves. There: problem solved! :okay:
Fnaar
Smutmaster General
Thumberland
I use them through the winter for warmth, as mentioned by others. feet stay mostly dry, but for me warmth is the thing.
I use these neoprene ones. Can generally get 2 winters out of a pair before the zips give out (though I've had them repaired before) or the sewing round the cleat holes give way (though I have sewed these up myself too, in the past). I last bought a pair 2 winters ago, and they remain unused so far, as my previous ones still have some use in them.
http://www.wiggle.co.uk/dhb-neoprene-nylon-overshoe/
