Good brakes and easy to set up once you get your head round the. Greg supplied this link originally:-
http://www.twowheelblogs.com/avid-bb7-disc-brake-set-and-tuning
I followed this, even buying a cheapo dremel tool to square off the cable outers, and I've had great braking performance. I chose to use Goodridge outer cables(
CRC £4 per meter), very stiff, but I haven't tried with normal cable outers.
I tweak my own setup slightly different to the above link but that's for lever feel preference on road levers. The above was based around the lever adjustability of a Speedial.
But I found it great for understanding the concepts, basically touch lever and caliper arm should move, no lag no loss in system. Once you have that then you can mess about with them in a similar way to a hydro brake. As in loosen mounting bolts and move either pad to alter rotor position within caliper. This method favours rotor offcenter towards the centre of the bike. But I probably have it more central than that now.
