bonsaibilly
I was going to tell you that but feared the usual lynching from the righteous millions for pointing out the obvious.
Bb
Bb
Bb
On the bright side I didn't fall off
Yeah that's a good shout. I looked at the Down tube and it's ok apart from one big chip that i doubt any tape would have stopped. Then I suppose when your off road with rocks and jumps there won't be much that can stop chips and dents. Like you said it's going to get chipped. Ironic really the first ride it gets a bigger chip than the one I took it back for
Will invest in some helitape, any recommended make that's better/easier than others to apply ?
Glad you're enjoying the new (gorgeousFirst ride today and on the descents I soon forgot about the sound of gravel hitting the bike frame from all angles. Like some said, after one ride is going to be chippedloved it and loved the bike
3m leading edge tape is the best stuff and it sticks like ****
You can cut it with a scalpel blade/ craft knife or very sharp scissors. The down tube is easy to do just measure the length width at top and bottom end, draw onto helitape, cut and fit. I radius the corners too.
Fitting can be tricky. The 3m stuff is a tad over 300microns so is fairly thick. This is perfect for flat areas like downtubes, you can get 150micron stuff too but being thinner it'll chip more easily. You can apply it by degreasing then wetting the surface with a very weak water/washing liquid mix or completely dry. Dry is a one chance affair! work from one end and press it down squeezing the water/air outwards. remove all water before it has a chance to stick. Once applied and all of the water is removed you can apply gentle heat from a hairdryer to help it stick or leave it somewhere warm overnight.
Removing is tricky once its been on a while. It can remove paint, especially where theres been any impact damage and the paint is just holding on. Heating it with a hairdryer will help it to come off.
That invisibike stuff is way too expensive for what you'd need. There'll be bits cut that you'd never use or will end up just sticking it on all over the frame. £10s worth of helitape would do the down tube, or try a local sign/graphics place for a stone chip vinyl.
Take a look on youtube for helitape on bike frames.
Looks like you have two widely spaced bosses on the underside of the downtube, so you could fit a Flinger similar.
It's drilled for the bosses so the fit would be neat and secure.
Might be possible to rig an extension to it to make it reach lower.
http://www.leedsbicycle.com/m2b0s80p1377/FLINGER-Front-down-tube-ATB-Mudguard
Whyte sell frame protector kits in the shop section of their website
