numbnuts
- Gone over the hill and far away
Hello the sun must have come out
and it's that time of the year
Peter Sagan cause a minor stir at the Tour de San Luis by racing with hairy legs.If you read the very excellent "The Escape Artist" by Matt Seaton, he explains the reasons for leg-shaving: firstly, it helps with massage (and is therefore only really required for racers and professionals) and secondly it's simply to do with the aesthetics and the look; Seaton reckons a rider with hairy legs would get laughed out of the peloton. As a side benefit shaved legs make it easier for an experienced cyclist to assess the build and the muscles of the rider in front and get an idea whether he's likely to be a rouler or a sprinter or a climber.
A third benefit is that yes, shaved legs would be slightly easier to clean and less painful when removing dressings.
I shaved my legs once and it was a complete pain; it took ages and clogged the drain. Never again. Those with curly hair ought to be aware of the possibility of folliculitis where a tightly curled hair recedes after cutting then pushes through the walls of the follicle rather than come out cleanly, causing rashes and infections which turn into boils.
If you're bothered about it, buy a hair trimmer and fit the depth limiter then trim leg hair down to a couple of mm.
Though that sometimes just encourages gravity to relocate the hair from the top of the head to other parts of the body..... AGE
nice sharing!!Hi all,
I'm new to this whole cycling stuff but now that I've started I've decided what they hell and gonna try the whole hairless legs haha. You've gotta try it at least once haven't you
So what would you all say is probably the best way of doing this in your opinions?
Shaving
Waxing
Veet
Or even stealing the mrs' epilator :S (ouch)
... What's the worst that could happen![]()
