CharleyFarley
- Japan
From what I've seen, Garmin is a popular bike computer but I bought two other computers before I knew about Garmin. Both of them are Cateye Padrones and are excellent computers if all you want to know is speed, distance, average speed, maximum speed and time actually riding.
They come with instructions for different size wheels, but I found they are not accurate if accuracy is something you desire. For instance, I have a beach cruiser I bought in January 2020. I soon swapped the tires for whitewalls. The instructions have a chart to tell you what number of millimeters to set it on, but this isn't accurate. So I took a soft flexible tape measure and attached it to the middle of the tire all the way around. I got a reading of 2038mm. That was then set in the computer.
A few months ago I decided to go back to black tires, but I didn't measure them for the purpose of resetting the computer. Today, I decided it really ought to be measured. Attaching the tape measure around the wheel, I got a reading of 2110mm, a difference of 72mm, or 2.38 inches. So I've been losing that much with every revolution of the wheel. It might not amount to much on a short ride but over several months of 7km every day, with a loss of 72mm with each revolution of the wheel, I'd say it was a considerable loss.
The chart lists a wheel size of 26" x 1.75" as 2023mm but the actual measurement of the wheel was 2038. That was the whitewalls.
The chart lists a wheel size of 26" x 2.10" as 2068mm, but the actual measurement is 2110mm. That's the new black tires.
Maybe I'm pumping the tires up a bit too much?
Anyway, I was wondering if the Garmins have to be set to tire sizes. How else will they know to measure the distance travelled? If they do, and a chart is provided as is with the Cateyes, they may not be giving accurate mileage.
