Mattonsea
- New Forest
Is there an known life span of a helmet, with average use and wear and tear. ? Motor bike helmets I think, correct me if Im wrong cant be older than a certain age. So is this comparable to cycling.
That is the conclusion of the above referenced article (http://www.helmets.org/replace.htm) as well. On the same web page there is also an article testing cheap helmets and expensive helmets interesting reading as apparently there are no significant differences in safety performance.It's the manufacturers that tell you to replace them. As for essential safety equipment, well....![]()
Indeed and in accordance with MattObrien's law (see New wheels are faster, fact) they therefore make you go faster !Expensive helmets look better though !![]()
Careful what you say around here, You'll open a whole can of wormsUntil it crashes. I still have an old Bell "light bulb" helmet from the 70's or 80's, as well as an old Avenir, but only drag them out in historical context. Otherwise, 3 years sounds like a good lifespan for something so important.
You're supposed to replace motorcycle helmets after a couple of years too.What are motorbike helmets made from? Is any motorbike helmet technology transferable to the cycle helmet?
