KneesUp
It's getting to the time of year where I try and remember where the charger is for my lights. I have a perfectly good front light, and a perfectly good charger (I did find it in the end) and a perfectly good battery. However, the cable on the battery is rubbish - I've cut the plug off twice and chopped out a 'bad' bit of wire, so it's now quite short. What I'd like to do is put new wire on, but as the plugs on the battery, light and charger all match - and more importantly, are moulded on - I need to source some waterproof connectors that are good for bike battery power (I've a feeling it's about 8v?) so I can just cut off the old ones and replace them, with a new cable on the battery.
However, there are so many to choose from on Farnell and RS, I can't quite find anything suitable - could anyone recommend something I could use? Ideally it needs to be a plug / socket with a gasket to keep the water out obviously. Thanks in advance.
