A recent attempt was made to steal my Boardman MX Sport but they couldn't break the lock so instead they bent both wheels and snapped the gear hanger. Also caused the frame to crack just below the seat by putting a boot against the frame and forcing it.
Halfords said i need to get a new bike or a new frame. I really hope this is not the case and the frame can be repaired so that i can get back to commuting and weekend rides.
Any advice would be greatly appreciated, especially somewhere in or around Nottingham who could do the welding.
That really p!sses me off. I've always been paranoid about that happening to my bikes during lockup - sad to hear it happened to yours. I Own the CX 2014 which shares a very similar frame to yours, they're notoriously strong and rigid.
The alloy they use on our bikes is 7000 series Alloy, 7005 to be exact - now this is hard for me to find as evidence as boardman only call it "X7 alloy"
I was unable to find any relation to that word apart from "7X" which is a common two-key phrase for "7XXX" - meaning the entirety of the 7000 series.
7000 series aren't great for welding with, there are problems with cracking and corrosion, apart from 3 series in that family; 7003, 7005 and 7039.
With the right filler (5356) 7005 can weld just fine. - The other advantage with 7005 welding is that it doesn't require liquid cooling when its heat treated, it can be air cooled throughout its whole process.
7005 requires less temp to artificially age it (Sub <400F?, this part is from memory.) than other series of alu alloys like 6000
So actually, a repair is quite plausible.
However, the problem is boardman bikes go for extensively good 2nd hand value, and by that I mean you can pick up a similar bike (cx or another mx) for £300 or less from the 2nd hand market. It's up to you, but there are your options. (or even, buy the frame 2nd hand, which can be Incredibly cheap too.)
Also, invest in an Alarmed lock if you haven't already, it can deter people from doing any further damage.
